- Need Help!- Citizen E32 Parameter Data Protected
Hello,
Im trying to change some parameters on our E32, but its data protected. Does anyone know how to turn off parameter data protect on those machines?
In "PLC-SW" page "13. PRM Protect" switch doesn't seem to effect anything.
Re: Citizen E32 Parameter Data Protected
1001//M is what I use on our A32's, A20's, and L20's when I change parameters. It enables parameter write. I can't remember if it's in Maintenance, or Parameter screen. MCSTRCT, I think, not near any machine now, so can't be sure. Input: 1001//M, change parameters, power down to accept changes and lock write mode, power back up. I would think it would work on the E's also. I can double check tomorrow, and let you know more specifics if you'd like. --------------- John
Maintenance Page, IFDIAG, then enter 1001//M. See if that works for you. ------------- John
jptech
Thank you. This works on E machines. I can change parameters now.
Junior Member
Hello.. We are looking for parameters of Citizen L20 5-axis CNC Swiss Sliding Head Machine with Mitsubishi Medlas 300 control from 1997.
Let me know if anyone could provide us with it.. Thanks Regards
Hi Plastomatch,
Did you get the parameters for your Citizen L20?
- You may not post replies
- You may not edit your posts
Forum Rules
