- Using Cutter Comp on a Citizen L20 XII
I am curious as to how cutter comp works on this L20……trying to use as how I am familiar with other machines is not working. I have tried using it on od turning with a b=program that follows.
T0303
(DCMT 3-1-14)
(55 DEG ROUGH AND FINISH THREAD DIA)
M3S1=2000
G96S250
G50W.591
G00X[#814+#815]Z-.1
G71U.025R.05
G71P300Q400U.015W.002F.004
N300G01X.24
G01Z0.0G42
G01X.25,R.005F.002
G01Z.065
G01X.2975Z.09
G01Z.230
G01X.25Z.255
G01Z.3
G01X.48
G01X.5,R.01
G01Z.35
G00X[#814+#815]G40
N400X[#814+#815]Z.35
G0X[#814+#815]Z-.1
G70P300Q400
G00Z-.05X[#814+#815]
G50W-.591
G97
T0
As is it will run fine unless I put I values on my T-Data page under offsets menu. I put in .0156 for my R and 4 for my P.
I have also tried -.0156 for R and G41….I am at a bit of a loss….thanks Jay
Re: Using Cutter Comp on a Citizen L20 XII
Can you please post a sketch of what you're trying to do? Should be G41, R=.0156, P=4. I'll try to help ------------- John
Thank you for your reply. I did get this working already. At first I was in the wrong offset area.
- You may not post replies
- You may not edit your posts
Forum Rules
