Looking for reccomendations for micro drills .01 -.03 for drilling 13-8 H900-1100 stainless. Would like to find something that works better than the non carbide titex drills we use now. Been looking at Mikron Crazy Drills......
Control the process, not the product!
Machining is more science than art, master the science and the artistry will be evident.
I would define that as a carbide drill not HSS...lol
tool life and cycle time.
Harvey Tool, MA Ford, Mits
Did you take a look at what Guhring offers?
Hi could i get some help on Crazy Drills. I am using 30XD for 14 mm holes in grey cast. And from the cutting data i've used S22000 F330 Q0.5 and the drill broke only after 60 holes. Even pilot drill broke after only 200 holes.
If i change cutting data results get only worse.
Help someone?
