- Newbie- face milling on sub-spindle. SR20-RII
Hello everyone,
can someone tell me or give me any idea on how does the feedrate work when milling on the face of a part using the C axis? also what are the preparatory G and M codes to do that? any sample programs would be greatly appreciated. The machine I work on is a star SR20-RII
Thank you in advance for your help.
Re: face milling on sub-spindle. SR20-RII
With the SR20-RII you have two choices
Per min feed G98 of Per Rev on the driven tool G101
There should be an example in the manual with a little change here and there should suit your needs
Regards
- You may not post replies
- You may not edit your posts
Forum Rules
