- Just In FOR EVERYONE, INTERPRETATION WITH LIVE TOOLS "CITIZENS"
MAKE CHANGES IF YOU NEEDED
Mill .190 cross hole T1200 USE Y-Z PLANE
M80 S3=3000
T1200(1/8, END MILL)
(MAKE 1 PASS)
(SET RAD AT R.0625, SET P AT 0)
G50 W-.3937
G0 X.6 Z.25 Y0 C0 T12
G19 (Y-Z PLANE)
G98 G1 X.4 F6.0
G1 G41 Y.190
G3 Y.190 Z.25 R.095 J0(THIS WILL MAKE 1 FULL REVOLUTION)
G3 Y-.180 Z.25 R.09(MAKE 1/2 A REVOLUTION AND EXIT THE CUT)
G0 X.55
G40(CANCAL TOOL NOSE COMP)
G18(X-Z PLANE)
G0 X.6 YO W-.1 T0
G50 W.3937
M80 S3=3000
(MAKE 1 PASS)
G50 W-.3937
G19 (Y-Z PLANE)
G98 G1 X.4 F6.0
G1 G41 Y.190
G3 Y-.190 Z.25 R.095(THIS WILL MAKE 1/2 A REVOLUTION)
G3 Y.190 Z.25 R.095(THIS WILL COMPLETE 1 REVOLUTION)
G0 X.55
G18(X-Z PLANE)
G0 X.6 YO W-.1 T0
G50 W.3937
( SAME PLANE BUT START THE CUT MOVING Z INSTEAD OF Y)
M80 S3=3000
(MAKE 1 PASS)
G50 W-.3937
G19 (Y-Z PLANE)
G98 G1 X.4 F6.0
G1 G41 Z.155
G3 Y0 Z.345 R.095(THIS WILL MAKE 1/2 A REVOLUTION)
G3 Y0 Z.155 R.095(THIS WILL COMPLETE 1 REVOLUTION)
G3 Y.180 Z.245 R.09(MAKE 1/4 A REVOLUTION AND EXIT THE CUT)
G0 X.55
G18(X-Z PLANE)
G0 X.6 YO W-.1 T0
G50 W.3937
(THIS WILL MAKE 1/4 0F A REVOLUTION PER LINE)
M80 S3=3000
(MAKE 1 PASS)
(SET RAD AT .0625, SET P AT 0)
G50 W-.3937
G19 (Y-Z PLANE)
G98 G1 X.4 F6.0
G1 G41 Z.155
G3 Y.19 Z.25 R.095(THIS WILL MAKE 1/4 REVOLUTION)
G3 Y0 Z.345 R.095(THIS WILL MAKE 1/4 A REVOLUTION)
G3 Y-.19 Z.25 R.095(THIS WILL MAKE 1/4 REVOLUTION
G0 X.55
G18(X-Z PLANE)
G0 X.6 YO W-.1 T0
G50 W.3937
(FACE MILL .2 DIAMETER SQUARE)
M80 S3=3000
T1400 R1
(1/8 END MILL)
(SET RAD AT .0625 SET P AT 0)
G0 X0 Y0 Z-.05 C0 T14
Y.35
Z.04
G17(X-Y-PLANE)
G98 G1 G41 Y.2 F6.0
X-.2,R.01
Y-.2,R.01
X.2,R.01
Y.2,R.01
X-.01
U-.13 V.13 G40
G0 Z-.05
X0 Y0 Z-.05 T0
G18(X-Z-PLANE)
M80 S3=3000
T1400 R1
(1/8 END MILL)
Y.35
Z.04
G17(X-Y-PLANE)
G98 G1 G41 Y.2 F6.0
X-.2,R.01
Y-.2,R.01
X.2,R.01
Y.2,R.01
GO3 X0 Y.1 R.1 F6.0
X-.2 Y.2 R.1 F6.0
G1 U-.13 V.13 G40
G0 Z-.05
X0 Y0 Z-.05 T0
G18(X-Z-PLANE)
- You may not post replies
- You may not edit your posts
Forum Rules
