I would bring out the 10.mm end first, and then pickoff on that diameter with the sub. You should use sub support when you mill the flat to avoid deflection. Since its brass, you might be able to do it in one pass. If you have any quality issues with one cut, you can also mill the flat in 4 segments to avoid pulling out of the guide bushing. looks like no backwork is needed.
