- Problem- star sv-32j I did a bad thing.....
Just got the machine. I need parameters 1023,2020,2022,2023,2084, and 2085. main and subside. I discovered that you can change parameters in the maintenance page. I did not know this. There is a difference between setting and settings! I have no backup parameters.
Later
Parameters
They are pretty serious parameters that you need
As there are two controller suppied for the SR32J
18iTB and the 32i B and depending on the serial number of the machine there also could be other changes.
I suggest you get intouch with you local Star Agent
As they either have a copy themselves or the factory will have a copy when the machine was shipped
- You may not post replies
- You may not edit your posts
Forum Rules
