Nema23 Plug and play wiring diagram for 12v outputs?
Results 1 to 13 of 13
Thread: Nema23 Plug and play wiring diagram for 12v outputs?
    Feb 2017
    Default Nema23 Plug and play wiring diagram for 12v outputs?
    Installing a water cooled spindle. I want to power my 12v water pump and pc fan with my cncrp P&P controller box. Are there any open 12v output connections?
    Photo or diagram please??
    Member ahren's Avatar
    Feb 2004
    Default Re: Nema23 Plug and play wiring diagram for 12v outputs?
    While there is a 12V power supply in the system, it is only a 2A supply, and some of this current is required for sensors and the optical isolators on the IO boards in the controller. I'm not sure how much current your pump requires, but I would suggest a separate supply for this.
    Ahren
    CNCRouterParts
    Member GigaWatt's Avatar
    Apr 2015
    I wanted to install the same setup however I changed my mind due to the specs Ahren posted. I went with a 120v pond pump and a 120v pc type fan on my radiator. Works great! Bought all from Amazon.
    Feb 2017
    Quote Originally Posted by GigaWatt View Post
    Well GigaWatt, I've following you this far, might as well keep it up. I got a submersible pond pump 120v and a flow indicator with temp display (with standalone 12v power supply) I got the spindle/vfd and cncrouterparts mount yesterday. The only weak link is the Belden 18/4 shielded cable. I see everyone using 16awg but (I may be wrong) it looks like the 2.2kw has 18awg inside the housing. I guess if it heats up, I'll upgrade.
    Attached Thumbnails Attached Thumbnails Nema23 Plug and play wiring diagram for 12v outputs?-2018-02-07-19-34-23-jpg
    Dec 2005
    motor at full load will draw approximately 9A so in a 20' cable you will have 4watts loss vs 2.5watt loss in a 16ga cable. no big deal
    Dec 2003
    There is also the option of using the VFD outputs to turn the pump on/off.
    Feb 2017
    Quote Originally Posted by sparkness View Post
    Now that's what I wanted to hear!
    Thanks!
  8. #8
    Feb 2017
    Quote Originally Posted by Al_The_Man View Post
    Hmmm, I may be returning the 12v power supply from Amazon. How is that done?
  9. #9
    Dec 2003
    You still need a power supply however.
    If a Huanyang VFD, it normally has two open collector transistors that can pick up a small relay, or the 3rd output is N.O./N.C. relay contacts.
    These are operated using the parameters PD050/051/052.
    You can pick a condition such as either when in run or At Zero speed etc to turn the output on/off.
    Apr 2015
    The CRP electronics has 2 - 120v relay outlets that can be controlled with Mach3. I control my pump & radiator fan with one and dust collector with the 2nd.
  11. #11
    Feb 2017
    Oh I forgot about that! Yes, I already have my router plugged into one and a button on my pendant for on/off so I'll just unplug the router and connect a power strip for the 12v power supply, water pump, gantry light..... that'll work great!
    CNCRP P&P controller is definitely worth the $$$
  12. #12
    Apr 2015
    Quote Originally Posted by 2012JK View Post
    You'll like the WC Spindle, so much less noise.
  13. #13
    Feb 2017
    I got the vfd programmed (got the settings off YouTube, I hope Rick is right) ???
    Attached Thumbnails Attached Thumbnails Nema23 Plug and play wiring diagram for 12v outputs?-2018-02-14-14-31-48-jpg
