Slate
Results 1 to 8 of 8
Thread: Slate
    Aug 2016
    Default Slate
    Just an FYI here. I was walking through Michael's the other day and spotted some slate plaques. Hmmm, I wondered, could I engrave those? Well, yes, we can. I used an eBay tiny V bit (its the yellow version they sell by the dozen for engraving, circuit boards, etc. - tiny little tip - flat on one side). I used 60ipm, router full blast (Bosch 1617), 0.005" depth per pass. Everything went very well and the look is nice. I went a total of 0.015" deep. The only issue was that the slate, being a natural product, is not flat. I used a dial indicator in the router to get it close. My piece had a hump in the middle, which is where I set Z zero. As a result, I had to go back and re cut some areas. I just set a deeper cut and went over them again. I didn't get a perfectly consistent depth, but it looks pretty good anyway. After I was done, it looks like the back of the plaque might have been flatter. I may have introduced some bow when clamping too, although I released the clamps and tightened them back "just enough." I also used tape on the bottom. I'll try and get a pic this evening.
    Anyway, just wanted to share that it worked in case anybody else is interested. Oh, Michael's has 40% off coupons weekly, so a 8x6 or so plaque is a couple of dollars. I might get a couple more to play with.
    Tony
    Member coherent's Avatar
    Apr 2003
    Arizona, USA
    Default Re: Slate
    You can also find cheap slate or other natural stone tiles at your local big box home center. Some work really well.
    Sep 2017
    Default Re: Slate
    Any pics of the finished part?
    Saturn 2 4848
    CRP Plug & Play NEMA 34, 2.2kw Spindle, Mach3
    Member awerby's Avatar
    Apr 2004
    Default Re: Slate
    You might think about using a spring-loaded tool holder for this, which will help with the uneven surface: Engraving Tools and Cutters, Spring Loaded Engraving Tools, Vacuum Chucks, Engraving Software
    Member rcheli's Avatar
    Nov 2005
    Default Re: Slate
    I've seen videos where they are milling circuit boards and it probes the board in a grid to get the topology and then accounts for the height differences while engraving. I don't know what software it was but it sounds like it would help in this process.
    John
    Aug 2016
    Default Re: Slate
    Neat, but I can't afford that!
    - - - Updated - - -
    Working on it.I forgot to grab a pic last night.
  7. #7
    Aug 2016
    Default Re: Slate
    This is the piece of slate I engraved. I is around 8x6 I think. Michael's has several shapes and sizes. You can see that some of the engraving is deeper. I recut several areas in 0.005" steps until I got to this. Anyway, I was pleased with the result. I'd prefer the depths to be more consistent, but it is a natural material, so.... I'm just thrilled that nothing exploded across the shop! And the tool and the slate cost me $3 maybe? Converting the bitmaps to vectors had the usual issues and I didn't do a good job cleaning things up, so it took forever. Plus, I had the tool moving pretty slow to be safe. Anyway, fun stuff. Learned something. Might go check out the Home Depot offerings as mentioned above.
    Tony
    Attached Thumbnails Attached Thumbnails Slate-slate-jpg
  8. #8
    Nov 2006
    Default Re: Slate
    Cool. Thanks!
Slate
Slate
