Truck Spacing
Results 1 to 15 of 15
Thread: Truck Spacing
    Jan 2007
    Default Truck Spacing
    I am using some CNCROUTERPARTS stuff, but my frame is 45 series rather than 40 series extrusion. I am interested in the outer end to outer end truck spacing on the standard Pro parts. For both the x and y axis. Thanks for the help.
    Apr 2010
    Default Re: Truck Spacing
    CNCRouterparts publish all of their designs on their web site. You should be able to find everything you need there.
    Start here: Machine Plans & Assembly | CNCRouterParts
    Jan 2007
    Quote Originally Posted by kjk2002 View Post
    Don't see any dimensions there....
    Jan 2015
    What size machine?
    David Gage
    Deep Sea Sound
    Jan 2007
    Any of the large machines would be fine. I am building 5'4" x 5'4".
    Jan 2015
    Can you share a picture and point to exactly what you want measured? I have a 5'x10' CNCRP Pro machine with the linear rails and I'd be glad to measure what you want. Then again, if you contacted CNCRP, I'm sure they'd be able to get you the measurements too as they were always responsive and provided all information I needed.
    David Gage
    Deep Sea Sound
  7. #7
    Jan 2007
    The carriage bearings on each rail on the x and y axis are spaced apart from each other. I am interested in the distance, from the outer end of one truck to outer end of the other truck on the same rail. Increasing this distance stiffens the axis, but reduces the travel for that axis for a given length of rail. It is a design trade and I am interested in what number they have chosen. It looks to be a little over a foot, but I can't tell much more than that.
  8. #8
    Registered ifeliciano's Avatar
    Mar 2005
    CNCRP has all their 14.1 version drawings in .easm format. Download the free drawing viewer and install it. The viewer has a "measure" tool you can use.
  9. #9
    Jan 2007
    Quote Originally Posted by ifeliciano View Post
    Thanks for the input. I had looked that up, but that version uses the old style 45 degree rail. I am using the newer 20mm Hiwin style rail that is used on the more recent Pro design.
  10. #10
    Mar 2005
    Quote Originally Posted by Bruce Griffing View Post
    I'm sorry Bruce. I'm not sure why I thought you were looking for the Vcon Pro measurements.
  11. #11
    Jun 2009
    Harbor Freight has free measuring tapes.
  12. #12
    Jan 2007
    Quote Originally Posted by brouser1 View Post
    I would gladly measure one if there was one nearby.
  13. #13
    Jun 2009
    Bruce-
    I was talking to the more than 260 people that have viewed your thread, I am sure at least a couple of them could give you that measurement very easily.
  14. #14
    Jan 2015
    Sorry I wasn’t able to measure this for you sooner but the truck spacing from outside edge of linear bearing to outside edge of linear bearing is 302 mm.
    David Gage
    Deep Sea Sound
  15. #15
    Jan 2007
    Quote Originally Posted by dgage View Post
    Thank you very much!!!
Truck Spacing
Truck Spacing
