Need Help! Machining Aluminum. 6061 vs 7075 - Your preference is?
Results 1 to 7 of 7
Thread: Machining Aluminum. 6061 vs 7075 - Your preference is?
    Registered ifeliciano's Avatar
    Mar 2005
    Question Machining Aluminum. 6061 vs 7075 - Your preference is?
    I need to make some indicator mounting panels out of .077" aluminum sheet and machine a "detent plate" from 1/2" stock.
    Which material would you prefer to machine with your CNCRP router?
    6061 or 7075?
    Gold Member LeeWay's Avatar
    Jun 2004
    Default Re: Machining Aluminum. 6061 vs 7075 - Your preference is?
    Both machine pretty well I think.
    6061 is usually cheaper, but 7075 would likely be more durable for the finished product.
    Lee
    Mar 2005
    Good. Will a squirt of WD40 every so often be enough to keep things lubricated or will I need a dedicated spray mister?
    I do need to build a shield to keep the chips from flying everywhere.
    Jun 2004
    WD40 will keep the chips from welding usually if you are within the right range. A dedicated mister would surely be nice but depends on how often you want to cut aluminum.
    You will absolutely have aluminum chips everywhere if you do not do something about it.
    Lee
    Mar 2005
    As always, thanks Lee!!
    Mar 2008
    If you're using a high RPM spindle I would use 7xxx series. 6061 is more likely to melt to the bit at high RPMs. I'm sure people will disagree with that. I don't use WD40 for cutting. I suppose it is OK but it is a pain to clean up. If you're going to cut lots of aluminum in the future invest in a Cool Mist system.
  7. #7
    Mar 2005
    Quote Originally Posted by warrenb View Post
    Warren,
    Thanks for the info. I can get between 8K - 24K with the spindle.
