CNCRP pro (LATEST) z-axis cable track hack
Results 1 to 16 of 16
Thread: CNCRP pro (LATEST) z-axis cable track hack
    Apr 2004
    Default CNCRP pro (LATEST) z-axis cable track hack
    I upgraded my CNCRP pro to the latest linear motion design this summer and was really missing the Z-axis track for cable management (esp with a water cooled spindle), so I decided to see if I could design some 3D printed parts to make the old z-axis track work.
    The solution turned out to be pretty simple... just two brackets. The only other thing I needed was one an extra cable track end since they are identical on both ends of the track now.
    The first bracket is an offset L bracket to make sure the track clears the z-axis chases while moving. It mounts through the same holes that hold the Y-axis cable track to the Z-axis carriage. I think I had to get screws that were a little longer.
    The second one is just a straight "popsiscle stick" with elongated slots for some adjustability. It mounts to the t-slots (with T-nuts) on the front of the z-axis.
    I printed them that at Shapeways.com. If there is any interest I can make them available for purchase.
    Pictures:
    CNCRP pro (LATEST) z-axis cable track hack-img_3779-jpg
    CNCRP pro (LATEST) z-axis cable track hack-img_3781-jpg
    CNCRP pro (LATEST) z-axis cable track hack-img_3784-jpg
    CNCRP pro (LATEST) z-axis cable track hack-img_3785-jpg
    CNCRP pro (LATEST) z-axis cable track hack-img_3787-jpg
    CNCRP pro (LATEST) z-axis cable track hack-img_3788-jpg
    CNCRP pro (LATEST) z-axis cable track hack-img_3789-jpg
    CNCRP pro (LATEST) z-axis cable track hack-img_3790-jpg
    Jan 2015
    Default Re: CNCRP pro (LATEST) z-axis cable track hack
    Really love that one too! Will have to print me one of those. Thanks for another great idea!
    David Gage
    Deep Sea Sound
    Registered ifeliciano's Avatar
    Mar 2005
    How strong is the plastic? I've thought about sending some designs to Shapeways to get printed, but material strength has always concerned me.
    Apr 2004
    Quote Originally Posted by ifeliciano View Post
    It seems to be holding up good. I think I see a *small* amount of flex/twist in the "popsicle" part, but otherwise fine.
    It is laser sintered nylon.
    Note that shapeways will let you print FDM PLA now.
    Feb 2017
    United Kingdom
    Neat hack, looks great. I'd be tempted to run the vac over the top of that, too.
    Mar 2005
    Quote Originally Posted by Kosh View Post
    Thank you..
  7. #7
    Jan 2015
    Material is one aspect, fill percentage (density), and thickness also matter. Plain PLA is cheaper but not quite as strong. ABS is stronger and handles slightly more heat. And then if you add fibers, that can make the part stronger but likely won’t have as smooth of a surface.
    So if you want stronger, specify a stronger material with more fill or thicker walls but each of these adds to cost and engineering is about making it work well without being too expensive.
    David Gage
    Deep Sea Sound
  8. #8
    Gold Member LeeWay's Avatar
    Jun 2004
    If they print with Pet G, that will be very strong and cheap.
    We use it to print out 3 of our guard parts here.
    The tail section, which has two steel roll pins embedded for strength. A latch for our stainless steel tail hook and all of our dust ports.
    CNCRP pro (LATEST) z-axis cable track hack-sg3d-jpg
    Lee
  9. #9
    *Registered User* Delloman's Avatar
    Aug 2018
    Can I buy the files I have my own printers to do the work
  10. #10
    Member ubergeekseven's Avatar
    Mar 2017
    Quote Originally Posted by LeeWay View Post
    I really like that vac attachment. I need that for my saw. Great and simple design there.
    Sent from my SM-N950U using Tapatalk
  11. #11
    Jun 2004
    Thanks.
    We have a little newer version of it now.
    We updated the tail hook latch.
    Attached Thumbnails Attached Thumbnails CNCRP pro (LATEST) z-axis cable track hack-r4512sg-jpg
    Lee
  12. #12
    Apr 2004
    Quote Originally Posted by Delloman View Post
    What format do you want?
  13. #13
    *Registered User* Squatch's Avatar
    Sep 2018
    This is what CNCRP sent me when I ordered the Z kit. No hardware or instructions, I just guessed how it was installed.
    Attached Thumbnails Attached Thumbnails CNCRP pro (LATEST) z-axis cable track hack-20181025_185340-jpg   CNCRP pro (LATEST) z-axis cable track hack-20181025_185354-jpg
  14. #14
    Aug 2018
    Stl or any cad format
  15. #15
    Apr 2004
    https://www.dropbox.com/preview/Publ...?role=personal
    Let me know if that works.
  16. #16
    Feb 2005
    Could always use yoru machine to cut those parts out of aluminum.
    Great design.
