Build Thread manual 4th axis milling
Results 1 to 5 of 5
Thread: manual 4th axis milling
    Default manual 4th axis milling
    Hey guys.
    I have a custom job to fabricate a couple of this benches. The legs are fluted with continuously changing radius. Perfect job for CNC.
    I am eagerly waiting for CNCRP to start selling 4th axis kit which would make continuous 4th axis machining a bliss but for now this is a question of positioning and indexing the stock.
    I have an old Vertex dividing head and a tail stock. Looks perfect for 4 sided flip milling. Actually, almost as many sided flips as I wish. Divider will go up to a 100 if I remember correctly.
    Ordered 1 pc Lathe Chuck 6" 4Jaw Independent w/Back Plate 1-1/2"-8TPI K72-160 sct-888 with the backing plate.
    Going to be setting up to mill on Sat.
    Any recommendations on small CNC bits to clean the fluting?
    Attached Thumbnails Attached Thumbnails manual 4th axis milling-bench-jpg   manual 4th axis milling-dsc_1639-jpg   manual 4th axis milling-dsc_1640-jpg
    Default Re: manual 4th axis milling
    Attached Thumbnails Attached Thumbnails manual 4th axis milling-dsc_1644-jpg   manual 4th axis milling-dsc_1643-jpg   manual 4th axis milling-dsc_1641-jpg   manual 4th axis milling-dsc_1642-jpg
    Attached Thumbnails Attached Thumbnails manual 4th axis milling-dsc_1645-jpg   manual 4th axis milling-dsc_1647-jpg
    Legs are about done. Will start on skirts tomorrow.
