Do people use loc-tite on them at all? I didn't, now i want to know. There are tons of bolts, so out would suck to redo it. Not to mention getting those red caps out. That's a day, massive half day of work.
The instructions are very good. One thing i would say, make sure you run your electric where you want everything to be. Not sure if you got the spindle, or a router. But i have a router right now and need to run another line to it. You can use the relay in the controller box for it, but if the power isn't seperate, there could be interference. So make sure that you have your router power and another line for the controller and another for dust collection of being triggered by the relay, right next to each other.
If you're using a router, you have an extension cord on it to the controller and then running from the controller to power. That could be a long run.
Spend as much time as you can leveling before moving on. It will save hassle later. I still don't have mine trammed well and I have to take the spoilboard off,in a small area, considering it's mostly filled with the crp4896.
Sent from my SM-N920V using Tapatalk
