Sharing my CNCRP PRO4848 Spoilerboard
Results 1 to 8 of 8
Thread: Sharing my CNCRP PRO4848 Spoilerboard
    Jul 2015
    Default Sharing my CNCRP PRO4848 Spoilerboard
    Finally got my CNCRP PRO4848 up and running, thought I'd share my spoilerboard as I spent a fair amount of time designing it waiting for the hardware to arrive. I used 2 sheets of 19mm MDF glued together (started with 5' x 10', then cut down to size approx 1300 x 1650mm). I added metric rulers along 3 sides, have 11mm holes cut in throughout the surface for M8 holddowns (using McMaster part #95596A200), and counterbores and through holes for attaching to the frame cross members. I carved the ruler with a Whiteside SC01 1/16" bit, 7mm deep so the text/guides will survive multiple spoilerboard resurfacings - note that some of the 0's chipped out when cutting those. I also have (4) tiling alignment through holes deep into the temporary spoilerboard to cut the entire board (I tiled it 800mm tiles, with 200mm overlap).
    This was a collection of other people's work on various forums/posting (here, Vectric forums, etc).
    Questions or feedback welcome; hope this helps someone.
    Attached Thumbnails Attached Thumbnails Sharing my CNCRP PRO4848 Spoilerboard-cncrp-pro4848-spoilerboard-image-jpg
    Attached Files Attached Files
    Apr 2004
    Default Re: Sharing my CNCRP PRO4848 Spoilerboard
    What do you use the rulers for?
    Jul 2015
    Nothing specific in mind with the rulers, thought it might be handy to have - certainly the grid for alignment is great, so adding the units of measure wasn't a big stretch.
    Nov 2010
    Quote Originally Posted by Kosh View Post
    For impressing the ladies!! (looks great, file saved for my next spoilboard)
    Feb 2017
    Nice spoilboard. Would it be possible to save it as a .crv - VCarve Pro file?
    Jul 2015
    Attached is the CRV version. Enjoy!
  7. #7
    Jul 2013
    I love the idea of engraving the rulers. I am going to borrow that idea for my next board.
  8. #8
    Feb 2017
    Thanks - I will use this on my next spoilboard
