I think I'll just screw my stock down in the corners, there is enough room and stick with the tabs. Because I'll be "chamfering" all the hole edges as well, it'll be easier. Point taken on
making the tabs thinner.
Now, I have used superglue to hold down shell when CNCing it for inlays. It works really well. The issue is getting it off. I've used acetone as a bath to remove it, but what I've found
is that only the small surfaced areas (which is fortunately the actual inlays themselves) will release easily. Ie, the acetone will only penetrate so far. Perhaps if you left it overnight it would
work better, but that stuff tends to evaporate as well.
What I have found works well with shell is just PVA glue. I used that to attach to hardboard blanks, and then I just put them in a bowl of water and boiled it in the microwave, they came off easily.
But that won't work for alum for multiple reasons...
oh, another technique I heard about, maybe this would work. Superglue the alum to a sheet of 1/4" hardboard, then after machining, flip it upside down and run it through a drum sander until the hardboard is gone.
Will have to check out the click spring stuff.
