PMDX134 to what motors?
Results 1 to 5 of 5
Thread: PMDX134 to what motors?
    Sep 2013
    Default PMDX134 to what motors?
    Is there any documentation using the cncrouterparts XML config file what Smoothstepper/PMDX126/PMDX134 motor port mapping is? New to Mach 3. Machine is built and itching to plug the motors in put really worried about getting the Y slave motor in the wrong PMDX134 port. None of the schematics on the site have of the current detail about the slave axis. Any one have a DIY kit were they had to figure this out?
    Thanks,
    Steve
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: PMDX134 to what motors?
    In Mach3, go into the Ports and Pins page and see which pins are assigned to each motor.
    Then see if they match what your PMDX-134 setup.
    UCCNC 2017 Screenset
    Apr 2009
    Quote Originally Posted by ssturges View Post
    Thanks,
    Steve
    Usually it's pins 8 and 9..... then just set up the A axis as a slave to Y. Bench test FIRST, you'll likely have to reverse the motor direction as well
    Just read again, I'll look at the schematic later. but they should be labeled as such somewhere on the board.
    Apr 2009
    Looking at the board, they're clearly marked axis 1, 2, 3, and 4
    Sep 2013
    thanks for replies, the key was starting with crp300 xml file(pmdx126 based) for mach3 not crp800 file which is tailored to cncrp own breakout board.
