Original cold rolled steel to new linear rail guide
Results 1 to 12 of 12
Thread: Original cold rolled steel to new linear rail guide
    Jun 2011
    Default Original cold rolled steel to new linear rail guide
    Has anyone converted their CNC Router Part machine from the original design using cold rolled steel to the newest linear rail design??? In particular using the red steel gantry risers?
    May 2012
    This was addressed by Cncrouterparts not long ago. I think the consensus was it's not possible since everthing is different. Including the extrusions. Apparently it's cheaper to buy a whole new machine.
    Quote Originally Posted by bobmagnuson View Post
    Nov 2015
    Default Re: Original cold rolled steel to new linear rail guide
    It can be done because I did it before CNCrouterparts came out with their new design. I wasn't happy with the wear on the soft 1018 cold rolled steel with V bearings so I changed it my own way. The 3" x 3' aluminum angle was milled flat and square on a milling machine and I mounted all the linear rails on 1/2 x 1-1/2" aluminum bar stock because it is much flatter than the extrusions themselvesOriginal cold rolled steel to new linear rail guide-001-jpgOriginal cold rolled steel to new linear rail guide-002-jpgOriginal cold rolled steel to new linear rail guide-003-jpg I'm sorry if the photos are dark I can try to provide better ones tomorrow
    Jun 2011
    Thank you! I knew there had to be someone who had done it.
    My thought was to mount the linear rail directly to the extrusion, but I was concerned about the flatness as well.
    I'm thinking of some type of aluminum plate to meld the original red steel gantry risers to the linear rail blocks. But I need to get some samples and see how it would all fit together.
    What size linear rail did you go with??
    Mar 2010
    America
    On my first build when Cncrouterparts first came out with there steel risers a few years back I purchased for build but than decided to go with profile rails. I just recently purchased there pro 4x8 with linear rails when that first came out for my shop.
    Original cold rolled steel to new linear rail guide-home1-jpg Original cold rolled steel to new linear rail guide-home2-jpg
    Jun 2011
    Quote Originally Posted by Dan911 View Post
    Thanks Dan.
    It looks like you attached the rail to a secondary surface which was attached to the extrusion??
  7. #7
    Mar 2010
    America
    There's through holes in steel for rail bolts and is connected to extrusion with T-nuts. Since I already purchased the 2 1/2" x 1/4" cold rolled steel to be used with the cncrouterpart carriages I decided to use as a mending plate for cross brace extrusions and use for rails to sit on. Thought it was a great idea back then...lol Machine is still being used today.
    Dan
  8. #8
    Jun 2011
    What size rail did you use? One or two blocks?
  9. #9
    Mar 2010
    America
    2 blocks on each THK 20
    Original cold rolled steel to new linear rail guide-cnc-20004-jpg
    Original cold rolled steel to new linear rail guide-cnc-20013-jpg
    Original cold rolled steel to new linear rail guide-cnc-20014-jpg
  10. #10
    Jun 2011
    Thanks. Looks line an upgrade is in my future.
  11. #11
    Nov 2015
    I am very interested in upgrading my CNCRP Pro 4X4 with linear rails. My cold rolled steel rails are wearing away terribly. Can you post or send me some more pics of your machine, showing more detail on how you did it. I think you really came up with a great idea!
  12. #12
    Jul 2013
    My steel is not wearing at all. I can sell you mine if you want !!!
