Need Help! SmoothStepper Warning - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: SmoothStepper Warning
  1. #21
    Registered fortyeight's Avatar
    Mar 2014
    Default Re: SmoothStepper Warning
    Thanks fellors,
    I will look in to all the thoughts.
    Just returned from my shift at work got a few things i would like to make these days off. As well as the finish of the new addition PRO4848, running cables now getting close.
    I will c whats works when if it comes back after my previous trys
    all the best,
    fortyeight
  2. #22
    Apr 2009
    I had problems with this as well. Aside from cleaning up Windows and the look ahead setting, you can try running the SS at the lowest frequency that will get the job done.
    For example, a typical setup could be 5mm ballscrews and G540. At 64kHz your max feedrate would be 377ipm... IF you can spin your steppers at 1920rpm with enough torque. One possible solution is to increase the microstep resolution on the stepper drive if possible.
    Figure out the frequency you need for max rapids with the setup you have and set the SS to the closest frequency, and if it runs fine you can raiae the frequency till you get a buffer under run, then you can dial it back.
    Really, if your calculated frequency for rapids is 40-50kHz, you probably don't need a SS - most processors from a few years ago pump this out easily with Mach3 DriverTest. Plus the lowly parallel port is capable of 2-2.5Mb/s... so that's not the bottleneck, it's Windows. But that's the price we pay for being able to use Windows with an infinite amount of possible configurations...
    The LookAhead feature in Mach3 really helps with smoothing out movement especially with 3D moves. Default in Mach3 is an abysmal 10 lines, but with today's computers can be aet to 200. The max is 1000 but I wouldn't go too far with it.
  3. #23
    Aug 2016
    I'm trying to learn how this stuff works. So, how did you come up with the numbers? How do you relate the Hz to feed rate? I'm using a Standard CNCRP setup.
    Thanks for the help....
    Tony - dazed and confused
  4. #24
    Apr 2009
    Quote Originally Posted by Goonk View Post
    For a ballscrew, take the controller frequency, divide by the steps/inch, and multiply by 60. Should work for r&p as well ..
