Originally Posted by
Semus
Just got off the phone with Cory from CNCRP. Once again, top notch customer service.
First off, I'd like to apologize for not giving enough information about my setup (feeds/speeds - rapids - acceleration, what sort of op I was running (boring/slot/contour), etc.). I'll try to be less vague next time ;-)
I believe Cory has gotten to the bottom of what happened here, and the solution is quite simple. Basically, I was running the Z-Axis a bit too fast which tripped the power supply to the Z. The Z and Slave axes use the same power supply, so when the Z goes out, the Slave goes with it. This is what caused the Slave axis to "lag" behind when I moved the machine back to it's home position. The Slave motor had no power, so it appeared as if it was functioning at a slight delay.
Anyhow, I'm looking forward to getting back up and running at higher speeds once the capacitors arrive ;-)
Thanks again, Cory!
