CNCRP uses their standard motor cable, which is 18 gauge shielded 4-conductor wires with XLR connectors.
The UgraCNC spindles have four connectors, one ground and three for the three phase power. UgraCNC cells a suitable cable on their website. I bought mine from McMaster. 16 gauge four wire shielded cable. It works fine. You definately need a well shielded cable suitable for movement in a CNC system.
Has Eric said above, though, it might be better for you to just go ahead a buy the CNCRP's plug and play spindle. Although my water cooled spindle is working fine, that's what I'd do if I had to do it again. Also, there is no savings if you damage yourself or your equipment. That's much less likely to happen with a plug and play system.
David Gage
Deep Sea Sound
Thanks for your concerns guys, much appreciated. I looked over the CNCRP page and didn't see where it said the M23 cable specs, hence my question here. So it took a bit more than 30 seconds of lurking around the CNCRP site to not find the answer
Thanks for the UGRA reminder. So 16/4 Belden or AlphaWire it is.
Don thanks for the info on the cable from McMasterCarr. BTW. If I buy the Spindle/VFD Plug-n-play kit, I will still have to make modifications. My controller is DIY.
I'll go electrocute myself now...
Very nice control box!
Thanks. The ESS patch cable routing is temporary. I was just checking the length of the cable and routing options.
Anyhow. I bit-the-bullet and ordered the 2.2kW 3hp Spindle from UGRA.
How long did it take for them to ship and did it ship with a manual/schematic/wiring diagram?
I ordered two spindles and two Delta VFD's from UGRA in the last several years. Both times, I received what I ordered in less than a week. Both spindles came with a Chinese language wiring diagram that was easy to figure out by looking at the pictures. You also get a plug that you need to wire that attaches to the spindle. The first VFD that I received came pre-programmed. The second was not pre-programmed but came with a clear english language instruction sheet. If you ordered their water cooled spindle, then you also need to get a pump. I chose to go with a closed circuit and bought a small pump and a radiator from UGRA. All three items had different size tubing connections but I was able to get the tubing and required adapters from McMaster-Carr. Here's a link to what I did: http://www.cnczone.com/forums/spindl...ml#post1982812
Last edited by DonFrambach; 02-23-2017 at 10:55 AM. Reason: bought tubing from McMaster not UGRA
Thanks Don. I ordered air cooled. I have two gaming PC that have custom water cooling loops, and based on my experiences, I didn't want a water cooled spindle.
Sorry. I wasn't trying to be offensive. You never know on here what a person's skill level is.
Some of the questions you were asking about trying to recreate the Plug n Play system seemed pretty basic.
Like "how many conductors are going from the spindle to the control box"
If you take a couple seconds and look at the data sheet or the picture on the CNCRP site you'll clearly find the info. Every question you asked has the answer on either UGRACNC.COM or CNCROUTERPARTS.COM
Or the size of the box, what's in the box, etc etc.
Literally everything you asked is listed on one of the two sites. Except the shielding bit. But if you do any reading (including the LS manual) they will say that you need shielded cable.
Again. If reading to find this basic info out is difficult, wait until you have to start configuring said vfd. Hooking up the thermistor from the spindle into the relay. Configuring the settings for that. Not to mention the 30 or so other parameters that have to be changed to get the LS VFD to work without blowing up your spindle.
Again. Good luck.
http://www.cncrouterparts.com/images/Spindle_VFD_4456c.jpg
There's a picture of the setup directly from their site. See how many of your original questions you can answer from just looking at this picture.
None. The lettering on the cable it too blurry, so I can't read it. Also that pic right there is the PNP system for using with the latest controller (CRP800 I believe), not with a DIY controller like mine, which is more like the older CRP300 using a PMDX-126 BOB and PMDX-107 Spindle controller. I do appreciate your help though.
I still need someone to hold the video camera...
None taken
Pictures aside, I didnt find the info on the cncrp site.Some of the questions you were asking about trying to recreate the Plug n Play system seemed pretty basic.
No. I didn't read they use a Belden 29500 or AlphaWire or Carol, etc...If you take a couple seconds and look at the data sheet or the picture on the CNCRP site you'll clearly find the info. Every question you asked has the answer on either UGRACNC.COM or CNCROUTERPARTS.COM
I admitted to missing this info in a previous postOr the size of the box, what's in the box, etc etc.
12AWG shielded cable. Page 2-8 Section 2.4 Specifications for power terminal block wiring . Not 18 AWG like UGRA sells. Hence my question here.Literally everything you asked is listed on one of the two sites. Except the shielding bit. But if you do any reading (including the LS manual) they will say that you need shielded cable.
No, not difficult, but tiresome. After reading tons of documents all day at work, once I come home, i just like to ask basic questions here and then go help coaching my son and the HS Pole Vault team.Again. If reading to find this basic info out is difficult, wait until you have to start configuring said vfd. Hooking up the thermistor from the spindle into the relay. Configuring the settings for that. Not to mention the 30 or so other parameters that have to be changed to get the LS VFD to work without blowing up your spindle.
No concerns on the VFD configuring. Im sure you will be really helpful
Again. I need a camera tripod.Again. Good luck.
You should take your own advise. I admitted to have not read the information in the description page. (http://www.cnczone.com/forums/cnc-ro...ml#post2005106)
I purchased this from Ebay, two years ago. Still running strong however my machine only gets a couple hours of use a week at most.
2.2KW WATER COOLED SPINDLE MOTOR ER20 & VFD INVERTER DRIVE 80MM DIAMETER CNC | eBay
Shipped from LA and was in hand in just a few days. There were no instructions but was about to find some for the VFD after going through the forums.
