You would have to build sealed chambers between the aluminum rail.
Also you probably won't get enough suction thru the LDF. Gerry runs a heavy duty CNC router for a living and I believe he said that machine uses a 10HP vacuum pump to pull thru the MDF or LDF surface sheets.
