Re: Finished New Build (48X96) Need help on setting up the makers guide.
Hi Rob,
See attached PDF for more information on the M12 connectors on your controller. The AUX inputs are currently set for normally open inputs, so you should be able to use pins 3 and 4 with the Maker's Guide.
Pins 3 and 4 on the connector are different than pin 9 on your board. Pin 9 on your board is the actual sensed input, the pin that gets taken either high or low when the connection is made. Pins 3 and 4 on the connector is where the wires from pin 9 on your board and the reference voltage/ground on your board are routed to.
