Hi everyone
I have Morbidelli author 504 (1994) and manual is in italian. maybe anybody has manual in english? pleeeease, help! thank you in advance
Hi everyone
any information, please!
Hi bud how did you go been a while I know...I know alot bout these machines can I help..names gordon
Milos mozebi e najdobro da go skeniras toa upatstvo sto go imas na italijanski i da go pretvoris vo jpg file a potoa so konvertor da go pretvoris vo word dokument i postavigo na online translator.Jas imam Morbideli autor 510 i na francuski e ima mnogu malku podatoci vo nego Pisimi na prestizdizajn@yahoo.com POZDRAV
I can help you contact me tad_ferreira@hotmail.com
Via iPhone of the Tapatalk
Sir,
The problem is that the air pressure is not enough, check the air pressure inlet; if you solve this, that error shall be gone.
Verify the pressure status?
I have manual for the machine but not understand for your use in the serial port.
Are you use Cadcam type Aspan?
hi gordon do you have step by step on how to reboot machine battery went flat on morbidelli 504 thanks my email is leigh4smith@me.com
if you want send file from pc to triapc need adjust tria pc setup,please follow step by step;
BASIC MENU = FILES = SERIAL LINE = FINISH ''OR'' STOP COMMAND = SERIAL LINE = COMUNICATION SETUP = (
Baud rate : 4800
Timeout TX : 5
Char. num. TX PADDING : 0
Block lenght in recept : 90
Block check type : 1
Char. repeate preffix : 126
Save incomplete file : 0
TX PADDING character : 0
TX START character : 1
TX END character : 13
Host ( MS_DOS=1,other=0) : 1
Parity : NONE
Timeout RX : 3
Char.num. RX PADDING : 0
Block lenght in trans. : 90
Char.prefix 8 bits : 33
Converts existing name : 0
Serial line : COM1
RX PADDING character : 0
RX START character : 1
RX END character : 13
= SERVER MODE .
Not : rs232 connection cable need cross ( 2-3 , 3-2) (RX to TX) gnd connect to gnd,use hyper terminal.
Yes I need help with this please....ttellig33@gmail.com
