Need Help! Morbidelli Author 504K RS232 settings - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
Thread: Morbidelli Author 504K RS232 settings
  1. #21
    Apr 2013
    Argentina
    Quote Originally Posted by beeonline View Post
    The type of program that you are referring to is called a post processor. It must be written specially (or at least a module of that program) for the actual machine you are running.
    For Morbidelli, Aspan has been producing & selling programs which incorporate post processors for these early Morbidelli's from the start,and continue to update on a regular but program costs many thousands new and is sold with dongle copy protection so can't just copy a program and run it on a second machine.
    Is your machine A503?. I have knowledge of A502, A504 & U550
    I think A503 closest to A502 but I could be wrong.
    Can you give me an idea of the layout. Drill pattern, x y & z dimensions etc
    I will attempt to contact you directly because I have some other ideas.
    regards beeonline
    Is Aspan the only software that works with Morbidelli Author 503 ?
    It´s too expensive in my country (Argentina)
  2. #22
    May 2013
    Serbia
    Hi everyone
    I have Morbidelli author 504 (1994) and manual is in italian. maybe anybody has manual in english? pleeeease, help! thank you in advance
  3. #23
    May 2013
    Serbia
    any information, please!
  4. #24
    Jul 2012
    australia
    Hi bud how did you go been a while I know...I know alot bout these machines can I help..names gordon
  5. #25
    Quote Originally Posted by CNCRouterMan View Post
    rofiksumartopo It sounds like you lost your plc perameters because of battery back up dead. Replace the battery and call SCM about sending you the plc perameters file and steps to load back into system.
    I'm having the same exact problem now, the battery died and the parameters are gone! Will SCM give me the parameters for free?
  6. #26
    Aug 2013
    Milos mozebi e najdobro da go skeniras toa upatstvo sto go imas na italijanski i da go pretvoris vo jpg file a potoa so konvertor da go pretvoris vo word dokument i postavigo na online translator.Jas imam Morbideli autor 510 i na francuski e ima mnogu malku podatoci vo nego Pisimi na prestizdizajn@yahoo.com POZDRAV
  7. #27
    Service SCM BR
    Guest
    Default Re: Morbidelli Author 504K RS232 settings
    I can help you contact me tad_ferreira@hotmail.com
    Via iPhone of the Tapatalk
  8. #28
    saddy's Avatar
    Feb 2015
    Indiana
    Sir,
    The problem is that the air pressure is not enough, check the air pressure inlet; if you solve this, that error shall be gone.
  9. #29
    Service SCM BR
    Guest
    Verify the pressure status?
  10. #30
    Service SCM BR
    Guest
    I have manual for the machine but not understand for your use in the serial port.
    Are you use Cadcam type Aspan?
  11. #31
    Activation process
    Sep 2016
    9td
    hi gordon do you have step by step on how to reboot machine battery went flat on morbidelli 504 thanks my email is leigh4smith@me.com
  12. #32
    Mar 2016
    Turkey
    if you want send file from pc to triapc need adjust tria pc setup,please follow step by step;
    BASIC MENU = FILES = SERIAL LINE = FINISH ''OR'' STOP COMMAND = SERIAL LINE = COMUNICATION SETUP = (
    Baud rate : 4800
    Timeout TX : 5
    Char. num. TX PADDING : 0
    Block lenght in recept : 90
    Block check type : 1
    Char. repeate preffix : 126
    Save incomplete file : 0
    TX PADDING character : 0
    TX START character : 1
    TX END character : 13
    Host ( MS_DOS=1,other=0) : 1
    Parity : NONE
    Timeout RX : 3
    Char.num. RX PADDING : 0
    Block lenght in trans. : 90
    Char.prefix 8 bits : 33
    Converts existing name : 0
    Serial line : COM1
    RX PADDING character : 0
    RX START character : 1
    RX END character : 13
    = SERVER MODE .
    Not : rs232 connection cable need cross ( 2-3 , 3-2) (RX to TX) gnd connect to gnd,use hyper terminal.
  13. #33
    Member NazZ's Avatar
    Jan 2024
    Quote Originally Posted by milos.k View Post
    Hi everyone
    Greetings,
    I hope this email finds you well.
    Just purchased a 1995 Morbidelli 504 CNC machine. I don't have the manuals but still can't work out how to home it.
    If someone could give me a few directions it would be much appreciated.
    Kind Regards
  14. #34
    Member NUMcontrolsguy's Avatar
    Mar 2024
    Quote Originally Posted by klabacita View Post
    Hi people.
    I have 2 machines:
    1; Morbidelli Author 504k
    Control Tria 7500
    2; Morbidelli Author 504
    Control Tria 7500
    Normally we load the programs via floppies, we want to use the serial port of the controller, but we don't have the manual, I have googling but I have not found the info.
    Some could help me with this info? I will build the cable what is the configuration? Someone have the manual for this machines?
    Last thing, how to setup the connection?(Parity, Stop Bit, etc, etc.)
    Thanks all for your time, hope someone could show me some light, I will apprecited, thanks again for your time!!!
    I am a mere 15 years behind here, but can provide some direct answers for anyone who may be encountering this
  15. #35
    Jul 2016
    Yes I need help with this please....ttellig33@gmail.com
