Why do I find that post funny?
/me shakes sleblanc to try to wake him before something embarrassing slips out
Anyone here running a Bussellato with Genesis Evolution? I'm having difficulty manipulating ficticious faces.
Did I miss something?
No, its probably just me. I have no clue what you are talking about, so in that light, it seems funny.
sleblanc, we use Genesis, but not evolution. You should ask this question on the Delmac website forum. You'll get good tech support right from the source.
Now that's funny!
I'd recommend reading the manual, but if its like ours, you'll be more confused than before you started.
You are correct. The manual has a page or two about ficticious faces... in poorly translated Italian to English!
No Hu you are spot on.
Read the first post aloud and try not to crack a smile.
For you metalworking guys:
http://www.delmac.com/pages/products-cnc-jet5.html
http://www.delmac.com/pages/products...ringheads.html
UCCNC 2017 Screenset
Anybody out there running on Genesis Evolution? I just start work with a company that has a Bussellato/Genesis Evolution router. I need a way of resetting the access level passwords.
Hi:
We're running Genesis Evolution> What exactly is the problem?
The Busellato folks gave me the default passwords and they worked. So, I am now able to get around in Genesis. The previous operator left things pretty messed up and I believe they took some of the manuals. I am currently stumbling through setting up the tool changer. If I get hung up on anything, I may seek out you help.
For not have any manuals, I have been able to make good progress. I have created a simple slot profile, imported into the "Program Editor", set up the proper tool in the changer and successfully compile the code with the optimizer.
When I run the code, the machine positions the tool in the spindle and sits there. The message bar states it is waiting for the tool change to take place.
Any suggestions or clues would be appreciated. I feel I am so close.
Denny
I have manual in italian language and i have the metod to make high level password, if you needed
If you have genesis evolution version 4, do it this way: set the date of pc at 10 december 2004, insert in the 'change password level' the value 1518.
If you have version 7, send my a email, the method for this version required two files that need to replace those supplied with the software.
Regards
eduardo_servicio@yahoo.com.mx
tpapass.x
en el directorio system encuentras este archivo algo asi. borralo
y luego vuelvelo a poner haber si funciona
I did not understand the passage, you deleted the file and then you put back? It worked ?
Non ho capito il passaggio, hai cancellato il file e poi lo hai rimesso ? Ha funzionato ?
