Hi have just joined the forum.
We have got a second hand record 1 and have a parts manual and all the NUM 720 manuals if you still need them.
regards Asterix13
Hi, as i mention in the post below, we bought used SCM Record 1. This is our first CNC center and we have no experience.
The problem is: we don't have documentation, the prorgramms, but only electical sheme.
Maybe some one know where i can found it or send it per email?
Google search does't bring much.
regards Asterix13
Hi i have been running a record on for the past 10 years. I have parts. num 720 manuals postprosesor for alphcam and a lot of experience.
regards p_ken
Hi p_ken,
Nice to hear from another record owner, can you help with this problem I have.
I have been running the scm record 1 for around 6 months but have been unable to get the drip feed working. Following the instructions from the NUM 720 manual does not work.
So I can only run very small programs + - 1200 lines of code
Hi p_ken,
Nice to hear from another record owner, I have been running our scm Record 1 for the last 6 months using AlphaCam but can not get the drip feed to work. The NUM 720 instructions do nothing so I can only run small file sizes + - 1200 lines of code. This means I have to run jobs broken in small lots. Can you help?
Regards Asterix13
Hi Asterix13
I have drip fed programs some time ago but cant totaly remember how.. we increased the memory. I will hunt through my notes and try and recall the process.
Hi fictionist,
Let me have your e-mail details and I will send Num 720 manuals to you.
File size for 720 is about 14meg.
I also have Num 820 if needed.
Do you use drip feed on your machine?
Regards asterix@sign-tech.co.nz
Thanks a lot for the quick response. My email address is design@woodlam.co.za
Regards form the sunny Cape Town
Hi p_ken,
we recently bought a used CNC machine and are missing the manual.
Would you mind to send me a manual ?
My email adress is hemengtingting@126.com
THANK YOU VERY MUCH!
Hi p_ken,
i am a member of CNCzone.
my email adress is hemengtingting@126.com
Thank you very much!
Hello everybody,
I also need a copy of num720 manuals in english.
My e-mail is avouzikis@hotmail.com
Greetings from Greece
Thanks a lot
Hi All,
Does any of you lot use Xilog or Xilog plus.
If you need any help just give me a shout regarding Xilog or Xilog plus.
Also I have an alphacam post processor for the NUM 720, NUM 750, also for the RECORD 220 I have two post procesors.
You might need to tweek them.
Shaun
Hi Chris,
I don't use drip feed.
The programs i use are stored on a server called (k drive).
I don't store any programs on the control.
When the programs are opened up in panel mac and run they are actually all still on the server and the programs run fine.
To do this all you need to do is put your control on the network and access is dead simple
If you need more info let me know and I'l do a demo.
Shaun.
If anyone has the programming manual for NUM720f i would be very grateful.
Email: ziga.lunder@gmail.com
Best regards
PS: What kind of a PC and software would be compatible with the Num720f for program storage and easier input? The machine is from Greda
i have been running a record 120, and i have hypermill open-mind version 9.6.
i need a postprosesor.
can you help ?
Hi Shaun,
I am working on a Record 220 & would certainly like an Alphacam post if you still have one.
Alan
I have a problem qith a record I qith num 720, i looking for manuals.
Facundo
facundo.perea@gmail.com
Raphael Huber from Switzerland is behind SubConsciousMind or short SCM. In 1997, with no musical or technical experience and having no one to ask, he started to teach himself everything he needed to know by simply tweaking till it sounded like music. Since then he has performed live internationally, released two and a half albums and carefully developed his own edgy and characteristic style.
