Try OneCNC. Way better price than Mastercam and Far superior support. Call Patrick at OneCNC west for a demo. Their post processor is super easy to modify, and Patrick will gladly help you out if you get stuck.
ISO is the "loose" term here, these machines will not run standard eia/iso/"fanuc" code. They will however run code from previous generations of their control software, If your CAM provider has trouble generating a post for Biesse Works native code , have them provide you a post for XNC or NC1000, it is the preceding control software and all BiesseWorks equipped machines will process this code. BiesseWorks is built on top of the XNC/NC1000 control software. As a side note, I would personally always have the CAM manufacturer demonstrate a working post for your machine prior to purchase.
Left Biesse,,,,doing some stuff with Stiles,,,,but i may not go back as mechanic,,,forums are keeping me swamped,,,keep me in mind if you need a post or something related,,
