hey guys, im pretty new to cnc's but i consider my self pretty mechanically inclined, and I am trying to tram my K2 2525LT and cant seem to find any adjustment screws, or slotted holes to adjust it with. i don't want to start taking things apart before knowing if ill make the problem worse, or doing a ton of work for a simple fix. the x axis is pretty good, but the y axis leaves about a fingernail thick step (i know, its not in thousands of an inch, im new, lol) and it shows up on all the cuts. is this a known issue, or something that there is no fix for, or can it be adjusted, or corrected with an aftermarket part or a hack. i thought about shimming it, but would like to try any other options before going through that.
thanks in advance!
also, how difficult is it to replace the router head with a spindle?
