Need Help! Morbidelli Author 500 Help with xilog 3
Results 1 to 3 of 3
Thread: Morbidelli Author 500 Help with xilog 3
    Sep 2017
    South Africa
    Default Morbidelli Author 500 Help with xilog 3
    Hi all I've got an axis problem on this cnc machine,I keep getting plc6,7,8 fault drives then the machine stands still and doesn't want to do anything I've tried restarting and switching of everything but still doesn't work but on some days it decides to work again.
    please if anyone can help me with advise how to fix or what causes the problem I would fully appreciate it.
    Jan 2015
    Default Re: Morbidelli Author 500 Help with xilog 3
    Did you check all saftey wires, bumpers... it means that machine doesn't have power
    Sep 2017
    I have an Auther 600
    I don't understand your error message.
    You need to understand what it's telling you.
    Like the limit switches on mine are normally high so if one dies as it did and it goes low and then into fault.
    So it could be dirty contacts some times it works sometimes not.
    Paul
