Need Help! BZT PF 600 does not work as expected
Results 1 to 1 of 1
Thread: BZT PF 600 does not work as expected
    Registered iakregnif's Avatar
    Nov 2013
    Werl
    Default BZT PF 600 does not work as expected
    Greetings from Germany,
    I got an issue with my new (used) BZT PF 600. I just tried to cut a small part out of a thin sheet of stainless steel. The dimension is approx. 30 x 20 mm. I use Eding CNC (similar to USB CNC). I use Estlcam to prepare the gcode (tab).
    The cutted part is much bigger than the dxf and tab file or g-code. Please find the attached configuration. Is it because of the steps per mm? The limitations (made by the seller) seem to be strange as well. Those are actually the physical limitations, which is stra ge(?)
    How to fix this issue?
    BZT PF 600 does not work as expected-unbenannt_en-jpg
    Attached Thumbnails Attached Thumbnails BZT PF 600 does not work as expected-unbenannt-jpg
