You should copy cfg folder from original pc to your pc
Im trying to configure another PC to mirror the xilog plus setup at work but not having much success.
When I open a program that has successfully ran on the original set up on the new PC it seems to be off scale and shows part of the model on each side of the screen please see attached images. Does anyone know whats happening I have restored the configuration files from the original xilog setup?
- Newbie- Xilog Plus
- Need help scm xilog
- Newbie- Xilog
- Xilog+ and W7
Hi dmitry83,
I have done this but I get error "magazine not compatible with electric spindle (T=101)" This is when I open a program that runs fine on the original setup.
Thank you I will give that a try
