Are you use Tria or Xilog?
We have an Author 430s machine (esa kvara 6), a battery was installed on it and the PLC parameter was reset. Now the machine is calibrated and travels along the axes, but does not see the tool. If anyone has a procedure for installing the PLC, please send it to the post office. pk_dami.servis@mail.ru
- Morbidelli Author 213
- Need Help!- Morbidelli Author 427
- Problem- inverter emergency on morbidelli 430s
Xilog
Copy the folder Kvara of the tour Backup
https://cloud.mail.ru/public/8tYg/g1moR4w33 here is my
Here is my Kvara Backup https://cloud.mail.ru/public/8tYg/g1moR4w33
Kvara folder copied, autosetup launched
Autosetup ran, it passes the window disappears
The machine is calibrated, but does not see any tooling
But you save the tool of the tool change?
The machine does not see the electrospindle, the drilling head and the tool magazine (does not calibrate and not display in the MDI)
In the Autosetup run from step 1 - 12?
yes
So the files inside the CFG folder are wrong.
Take a backup and copy the CFG folder.
Rename the existing folder by example cfg_old and then paste it from the backup into the Xilog Plus folder and check.
If it still does not work, it means that the data in your folders should ideally be a connection team viewer with the SCM.
I did everything as advised - there is no effect.
There are suggestions that the file structure in KVARA is not properly distributed. Does anyone have a backup copy of KVARA 4.7 disks (C, H, F, I)?
