Need Help! PARAMETRIC PROGRAM
Results 1 to 2 of 2
Thread: PARAMETRIC PROGRAM
    Registered paulicarpiodavi's Avatar
    Apr 2017
    Saudi Arabia
    Default PARAMETRIC PROGRAM
    HELLO EVERYONE, SOMEBODY HERE WHO USES SCM ACCORD 25FX OR ANY SCM MACHINE THAT USES XILOG MAESTRO?
    I AM A NEW USER OF CNC MACHINE, I NEED TO WORK ON PARAMETRIC PROGRAMS, BUT I AM EXPERIENCING DIFFICULTIES
    IN HINGES. I NEED TO MAKE PARAMETRIC PROGRAM FOR 4 HINGES WHICH HAS THE SAME DISTANCE. ANY EXPERTS IN PARAMETRICS
    PLEASE HELP! THANKS A LOT IN ADVANCE!!
    what formula should i put in middle top and middlebottom in order to make it all equal in distance?
    Attached Thumbnails Attached Thumbnails PARAMETRIC PROGRAM-untitled-jpg
    Paul
    Service SCM BR
    Guest
    Default Re: PARAMETRIC PROGRAM
    It's a little complicated to explain without giving an example here. But you need to position your hinges by dividing by the length of the Panel. Taking into account the spaces between one and the other. Where are you licensed? The Technician who installed the machine can help you.
PARAMETRIC PROGRAM
PARAMETRIC PROGRAM
