Need Help! Windows Xp 32bits Xilog3 - Kvara on SCM 80 Tech Plus
Results 1 to 13 of 13
Thread: Windows Xp 32bits Xilog3 - Kvara on SCM 80 Tech Plus
    Jan 2017
    Brazil
    Default Windows Xp 32bits Xilog3 - Kvara on SCM 80 Tech Plus
    The Old Computer that uses Windows 98 died. then I start to migrate to Windows XP.
    First is the Xilog3 I have the backup of complete folders
    Seccond the Kvara I have the backup of complete folders
    Then I start a clean setup of Windows XP.
    I did the configuration to make Windows XP to behave as monoprocessor OS
    Install the Drivers
    Everything OK til now...
    I upload the files to
    When I try to Open the BaseMenu this Message Appears.
    Attach 1
    And Xilog as it shows on Attach 2
    Need Help, I try everything... Serial Ports are Working Flawlessly as Serial Cable has been tested with sucess...
    I apreciate any help....
    Attached Thumbnails Attached Thumbnails Windows Xp 32bits Xilog3 - Kvara on SCM 80 Tech Plus-base-menu-png   Windows Xp 32bits Xilog3 - Kvara on SCM 80 Tech Plus-xilog-error-png
    Service SCM BR
    Guest
    Default Re: Windows Xp 32bits Xilog3 - Kvara on SCM 80 Tech Plus
    Verify the COM on the PC and CN.
    Verify the file Xilog3.ini if the settings is COM correct and it is working correctly.
    Jan 2017
    Brazil
    I have already check it for many times... it has the same configuration as it was in the old computer.
    Attached Thumbnails Attached Thumbnails Windows Xp 32bits Xilog3 - Kvara on SCM 80 Tech Plus-img-20170117-wa0121-jpg   Windows Xp 32bits Xilog3 - Kvara on SCM 80 Tech Plus-img-20170117-wa0120-jpg   Windows Xp 32bits Xilog3 - Kvara on SCM 80 Tech Plus-img-20170116-wa0023-jpg   Windows Xp 32bits Xilog3 - Kvara on SCM 80 Tech Plus-xilogini-png
    Service SCM BR
    Guest
    Try modify xilog3.ini.
    Put ; in the third line and delete ; of the second line.
    Because I remember the baud rate correct is 9600
    Jan 2017
    Brazil
    I think I found the error, there's a file, params.cfg, I couldn`t copy that file, it say that file is corrupt...
    that's the only thing is different between one folder to other...
    Jan 2015
    Try to set to only one cpu core In msconfig( google it )
    Other thing could be com cable. Pin 2 and 3 must be switched in win xp.
  7. #7
    Jan 2017
    Brazil
    Quote Originally Posted by dmitry83 View Post
    Thanks for answering my comment gently....
    One more question
    This Pin setup is made by software or Phisical?
    Regards
  8. #8
    Jan 2015
    Quote Originally Posted by betancour View Post
    One more question
    Regards
    Phisical. On com cable from plc to pc are 3 wire. 2,3 and 5
  9. #9
    Jan 2017
    Brazil
    Pins are swiched now but still have the same error
  10. #10
    Jan 2017
    Brazil
    I`ve made everything that people recommend to do
    But still I can not make it work in Windows XP, I wonder if it`s possible to make a Win9X VM, and make it work with standart Virtualized Serial PORT.
    I apreciate the help
    Kindest Regards
  11. #11
    Jul 2014
    Russian Federation
    Open the KVARA.ini file in the KVARA folder
  12. #12
    Activation process lamhon's Avatar
    Nov 2018
    Quote Originally Posted by piratman1 View Post
    hi, help me
    The machine Scm tech 80 show Error 4118 , communication failure with CNC.
    lamhon
    Attached Thumbnails Attached Thumbnails Windows Xp 32bits Xilog3 - Kvara on SCM 80 Tech Plus-11-jpg   Windows Xp 32bits Xilog3 - Kvara on SCM 80 Tech Plus-22-jpg
  13. #13
    *Registered User* Davisro's Avatar
    Dec 2018
    Dears,
    The same problem, can´t run the Xilog3 on XP or on higher WIN. Betancour have you solved it?
