- Need Help!- SCM Record 120 Error code PLC26 Emergency cause air
Aquired an older Record 120 that has been no use is a few years. Going through error codes one at a time. Starting with this one.
Any recommendations? Better yes is there an online copy of the manual that anyone know about? thanks
Augie
Re: SCM Record 120 Error code PLC26 Emergency cause air
Sorted out that error, had a loose fitting.
- You may not post replies
- You may not edit your posts
Forum Rules
