Don't understand all values you have like MOD( in front , but in xilog3 or Xilogplus you can use L or PAR function
L NH =(((DX-9*2)/1.2598)+1)/32
XBO X=50 Y=50 Z=10 R=NH x=32 D=8 N="P"
hi there!!
I am sorry if I am on the wrong place..
does any one knows how to make a parametric program where the line boring (amount of holes) increases or decreases as the panel size increases or decreases and always have the same distance on both ends?
I have something similar in WoodWop but I can't figure it out in xilog3 or maestro. This are some of the formulas I use in WoodWob
amount of holes - NH=MOD((L-9*2)/1.2598)+1
starting point of line bore - XC1=(L-DL)/2
distance from first to last hole - DL=(NH-1)*1.2598
thanks in advance!!
Thank you for the quick response, I think that value make the number a whole number instead of a number with decimals, for instance (((DX-9*2)/1.2598)+1)/1.2598 is 39.85, in woodwod that value (MOD) will round up the number to 40 (amount of holes in a piece 80" long , DX=80.)
I try the formula you gave me but it only shows 1 hole
you can test your results with line
PRINT "Value of NH=?d ; DX=?d" NH DX
DX is the length of your plate. Like L in woodwop.
Then if DX=600mm with formula NH =(((DX-9*2)/1.2598)+1) is result 462 holes
In Xilog for round function is RD round down and RU round up
L NH =RD(1.9) is 1
L NH =RU(1.9) is 2
Hello, dear colleague.
To perform a parametric program xilog, you could should use either DX or dy- and also the IF function.
For example DX = DY = 500 600
XBO X = 50
XBO X = DX-50
XBO X = DX / 2
XBO X = DX (DX / 4 + 50) IF DX <= 500 and DY> 601
This are just examples but using these codes and functions you get a parametric program Xilog.
You can also declare variables using the function L
Example:
L AA = 50
XBO X = DX-AA
Ok?
Enviado do meu iPhone usando Tapatalk
