This is the door of electrical cabinet. The switch not work correctly. Verify the switch with the tester.
Via iPhone of the Tapatalk
Hello. I recently purchased a used record 130. Upon initial start up it is throwing error code plc130-needs maintenance conditioner. Does anyone know how to solve this code?
The same error appeared in my routech just a couple of hours ago. Couldn't find a problem. Help plz.
I'm not sure if this information would help, but this error may also occur when there is a variance between the network address of the target (connected device) which has been set to display and your network address which has been set on the connected device. The solution is quite simple, you need to change the target and the network address via settings. You can also search for the info at https://www.socool.sg/ because sometimes they post the info about the common errors. So, if checking out the switch or using this method doesn't help you, then you should definitely call a repair technician.
