Need Help! Milling wood on a VMC designed for metal
Results 1 to 3 of 3
Thread: Milling wood on a VMC designed for metal
    Jul 2015
    Default Milling wood on a VMC designed for metal
    Does anyone have any experience milling wood on a machine designed for metal? I've never done any woodwork, what range of RPM is wood milling done in? I assume i'll need tooling designed specifically for woodwork? The main obvious things i can think of is to obviously run it without coolant, set up a vacuum, cover the coolant drains. Are there any other issues i could run into?
    Dec 2006
    Default Re: Milling wood on a VMC designed for metal
    I was able to machine brass, stainless, walnut, ash, and white maple chess pieces on a Grizzly G0602 lathe using the same bit that I ground from a parting blade. The wood pieces had to be redesigned slightly to avoid the thin sections but other than that it worked well. I did not run the lathe much faster than when I ran the brass pieces. I also did not to run the lathe at maximum speed as I was concerned with excess wear though it may have been unfounded.
    Best Regards.
    Carl
    Attached Thumbnails Attached Thumbnails Milling wood on a VMC designed for metal-chesssetreduced-jpg
    Feb 2011
    Have you looked at the Gwizzard software? It is a speed and feedrate calculator. I seem to recall that Bob has some figures calculated for wood.
    Think they offer a free demo as well.
