Is it possible to change edit Bre.Ma Eko 902's clamping system? When I try to run a +1900mm groove, the machine will clamp in the center, is it possible to clamp from end to end? Because everytime it clamps in the center, the grooving would get misaligned: The rollers are suppose to keep it straight but when it reaches the end of the fixed rollers(see attached photo), the right side of the panel will decline because of the uneven clamping system.
