Hi all
I have morbidelli 500s cnc , i try to let barcode work out but no luck
i just configured the barcode reader well but my problem is the command formula that the barcode will understand ( job file command formula) and which code xilog will understand ? (code 39 or code 32 or ... ect)
thanks
IDEAS?
How model of the your bar code?
Via iPhone of the Tapatalk
I print barode in code39 font
And i use serial barcode reader
Help appreciated
Hi
I use this barcode reader :
ID Tech EconoScan II CCD Bar Code Scanner
Any help please ?
Hello Colleague,
With only two this information will not help you.
For the PanelMac Software read bar codes they should be the EAN128 class.
Not any player that works. It should be a:
Griphon 4100 or
Honeywell (MS9535 (COM or USB) (COM adapter USB-Serial required and Profilic driver)
Honeywell 1202G (USB).
With any of these three player models on hand there need to configure the same.
In the Windows and PanelMac.
You need to be more explanatory about your problem or question about reading bar code on the machine with PANELMAC And XILOG
Enviado do meu iPhone usando Tapatalk
Thank you
I"ll try it
QUOTE=Service SCM BR;1944126]Hello Colleague,
Griphon 4100 or
Enviado do meu iPhone usando Tapatalk[/QUOTE]
Is it ok?
