Hi Hugo, do you can start the MAIN CPU bios ?? How do you do ??
Regards
I hope I'm in the right forum... I got a Walter HMC 500 and I have the next issue... My partner has replaced the CMOS battery of the MAIN CPU and the configuration of the BIOS has lost, we tried to start the MAIN CPU BIOS setup but we don't know how... Anyone can help us?
Thanks in advance
Regards
I know this is an old thread but I want to see if anyone has any information on a similar issue.... We are getting a CMOS RAM does not exist fault... I am assuming this is similar to a typical RAM card but I do not know which... I also need options to repair this or reflash what needs to be done... Any input will be greatly appreciated.
Hi Miller i can comment what we do when we have te problem:
May be you need to take some pictures from BIOS Setup
1st We discconect the cpu boards and clean the pins with an eraser and inset it again
2nd change the date in the bios and y DOS we use a date in 1996 (we have a 2YK)
Check Disk with scandisk and try
I hope this will help you
