Need Help! WinXiso-Xilog
Results 1 to 14 of 14
Thread: WinXiso-Xilog
    Apr 2008
    Default WinXiso-Xilog
    Hi All,
    I I am trying to generate code for an SCM Routech with Aspire. I have a post processor and it generates the .pgm file I need. The issue is I don't have access to the CNC at the moment and I wan't to verify that the post is correct and I cannot read the code in the .pgm file as it is not a standard text file.
    Would anyone be able to convert the pgm file to a .xxl file for me using WinXiso? Or possibly share WinXiso with me? Then I can read the file and verify that the code matches the sample files that I have been given.
    Thanks in advance.
    Richard
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: WinXiso-Xilog
    Are you sure you have that correct?
    On our Morbidelli, the .pgm is a binary file. I wrote an Aspire post to create the .xxl file, and used WinXIso to create the .pgm file.
    UCCNC 2017 Screenset
    Apr 2008
    Yes.. My post generates a .pgm file l just can't read it at home. I know what the
    Xxl file should look like so I want to use winxiso to convert from .pgm to .xxl. Which it can do. Then l can verify the output of my post.
    Would you be able to convert a .pgm file for me?
    Regards
    Richard
    Mar 2003
    Shelby Township
    .zip it and post it here and I'll see.
    Apr 2008
    SCM Xilog ISO (mm)-POST-Test.zip
    Here you go.
    If you can covert it to an .xxl that would be great.
    Also if you are able to share Winxiso that would be good.
    Richard
    Mar 2003
    Shelby Township
    Either you're not doing it right, or your machine is different than ours.
    With our machine, .pgm files are binary. We output .xxl files from our CAM and convert to .pgm with WinXIso.
    As such, your file doesn't work, as WinXIso expects .pgm files to be binary.
    Renaming your file to .xxl, and running it through WinXIso results in a binary .pgm file, which I've attached.
    Attached Files Attached Files
  7. #7
    Apr 2008
    Thank you. I will look at the file you sent.
    So it sounds like my post processor is changing the extension to a .pgm but not converting it to binary.
    Thanks for your help.
    Sent from my HUAWEI U8681 using Tapatalk
  8. #8
    Apr 2008
    Is there anyway you could send me the winxiso .exe? This way I can debug this post before l get access to the controller.
    Thanks again
  9. #9
    Mar 2017
    Turkey
    Hi All,
    First apologize for my bad english. I'm use to Morbidelli Author 430S and i have a *.pgm problem. How can i found a download link for Winxiso.
    Thanks.
  10. #10
    Aug 2016
    Bosnia And Herzegovina
    Please send me your e-mail so I can send you Winxiso.
    Regards.
  11. #11
    Hi there alias_s im also looking for WinXiso would you be able to help
  12. #12
    Member Fjespamer's Avatar
    Sep 2019
    San Martin
    Hola por casualidad tienen un postprocesador para un scmtech z25 estoy usando alphacam y no sé cómo convertir esos archivos .anc a pgm
  13. #13
    Jan 2016
    I need a program to convert outout file from Aspire to .PGM for Moorbidelli U26.
    Thank you
  14. #14
    avivco3's Avatar
    Mar 2022
    I looking for download link for Winxiso too.
  15. #15
    Member bnsnlai's Avatar
    Oct 2022
    Quote Originally Posted by alias_s View Post
    Regards.
    my email is bnsnlai@hotmail.com
    Please and thank you also looking for Winxiso
  16. #16
    Member Hugo_Hans's Avatar
    Mar 2022
    I assume that this is solved?
  17. #17
    Mar 2022
    For the Information, I am able to use XConvertor(Maestro), WinXISO (Xilog) and CNVRT for older machines.
WinXiso-Xilog
WinXiso-Xilog
