I can't comment on the quality of these 2 specific machines, but they look like solid, production level machines. Just understand that you can't do lathe work on a flat bed router like these that you use for cutting and drilling plywood sheet without adding another axis to rotate your leg spindles. I personally haven't seen a machine that will easily switch between ply, foam and fabric cutting. I'm not saying it can't be done, but at the very least you'd either have to have multiple z's for different type cutters for the different materials or you'd have to swap out cutters/fixtures to accommodate them. These types of materials normally require different cutting techniques and so a dedicated machine for the specific material would be more common. If someone knows of an "all in one" machine/system that can cut wood or foam or fabric easily, they should chime in. My quess is if it exists, it would be very very expensive when compared to a production cnc router. If you could work out a visit to a owner/shop who uses one of the machines you listed (or other make/model) and see it in use and discuss it's capabilities, pros and cons, it would make your decision easier.
