Where can I find Xilog software? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
Thread: Where can I find Xilog software?
  1. #21
    Aug 2014
    new Zealand
    Default Re: Where can I find Xilog software?
    Thank you Barada...very uselfull info. However..the NC is working fine, I have already loaded the PLC and PAR files previously using a similar schematic. The big issue is that I cannot get the NC to read a .PGM file....I keep getting the error "Invalid File Format"
    More searching over the internet leads me to believe that this old NC requires a file called cnvrt1.1.exe to convert to PGM files and not WinXiso
  2. #22
    Aug 2014
    new Zealand
    Thanks for that Service SCM BR....the problem is not the PLC and PAR files...it is to get the NC to open/edit .PGM file created with Xilog.
  3. #23
    Jan 2015
    Spain
    We are a little carpenter's workshop (3 coworkers) and we have purchased an old machine at auction module. We had expectations improving our productivity, but sincerely, we have no idea how we could optimize times programing our machine out of TRIA7500. We can only program it by typing out the manually in the machine consuming excessive time.
    Is Xilog the appropriate software to be able to program our machine in an easier way?
    Where could find the necessary software?
    How to install Xilog on my PC?
    Do exist a manual or tutorial for Xilog?
    Is it necessary to downgrade the OS to 32bits in order to use Xilog?
    Thank you in advance!
    Machine: Morbidelli 503
    Year: 1997
    Serial Number: AL3514
  4. #24
    Aug 2014
    new Zealand
    @AntonioC
    We purchased the A213 (tria7500) a while back on auction and took me 2 months and countless hours on the net to figure this out.
    For our NC, xilog and xilog plus does not work as the NC does not recognise the .PGM file format.
    This is how we resolved it:
    1. We open the .DXF file in Aphacam and save it as .ANC file.
    2. We rename the .ANC file to .TXT file
    3. then we use the CN75NEW.exe file, run in DOS mode to convert the .TXT file to .PGM
    4. We then send the file via NULL-MODEM cable to NC
    5. Open the file in EDITOR on NC and verify it.
    Done..
    Hope this helps...send me an email if you require more info or any of the files etc
    mail at aucklandcabinets dot co dot nz
  5. #25
    Service SCM BR
    Guest
    Default Where can I find Xilog software?
    Thankyou auckcabs for your answer.
    For Antonio and others
    The Xilog(3, plus, maestro) only Run in PC(Windows).
    Tria Run in plataform unix developer for Esa-Gv.
    Via iPhone of the Tapatalk
  6. #26
    Jun 2015
    españa
    Hola muy buenas, yo tambien tengo el mismo problema, estoy buscando el xilog para poder programar en mi ordenador portatil y luego pasarlo a la maquina, pudiste encontrar el xilog en algun lado
    saludos
    Quote Originally Posted by gbrlbll View Post
    Thank you very much!
    I found the serial number for my machine, it is AL1-001909
    When I write a program in editor and save it to the machine, it is in the PGM format already. The machine has something called esacad on it which seems to be some kind of graphical programming interface. It is very basic in functionality from what I can tell, I played with it only a little bit though. I have absolutely no documentation on this esacad and find even less on the net. But either way with Xilog plus I should be able to do what I need.
    Thanks!
  7. #27
    Service SCM BR
    Guest
    https://mega.co.nz/#!lspwzSYS!UPwuV3...u79Nxn8gBch20Q
    Link for download of the Xilog Plus.
  8. #28
    Jun 2015
    españa
    Hola Amigo
    muchisimas gracias por el link de descarga, pero no funciona le doy al setup para instalar y no instala
    muchas gracias amigo
  9. #29
    Service SCM BR
    Guest
    What the operation System? 32bits?
  10. #30
    Service SCM BR
    Guest
    Hi, it is solved?
    Enviado do meu iPhone usando Tapatalk
  11. #31
    Jan 2017
    Quote Originally Posted by Service SCM BR View Post
    Hi, it is solved?
    I have the software on my machine, but not the manuals, do you have a copy you can link me to? I am running Xilog3 on a Record 120 built in 2000
  12. #32
    Dec 2017
    Default Re: Where can I find Xilog3 software?
    hi, i have scm recorder 240 an i need a software for this cnc. my plane produce cabinets an mdf doors for them.
  13. #33
    Dec 2017
    i also have morbideli a 213 need tcl file! can u someone help! code is al 1639
  14. #34
    Member BraMan's Avatar
    Jun 2020
    I have same problm.
  15. #35
    Member Knof's Avatar
    Oct 2020
    Can i use xilog to program old SCM Unitech KLETRA 400?
  16. #36
    Jan 2017
    hello Service SCM BR.. we have also problems loading plc and par files to the scm tech 99 we dont have the backup disk.. were can we find this information and how we load in to the machine .. thanks
  17. #37
    Apr 2018
    Jordan
    xiloog 3 xilog plus requested !?!!!
  18. #38
    Colleagues,
    I have a MORBIDELLI m100 cnc machine.
    We use the old version of the licensed XILOG MAESTRO-EDITOR with a USB key for it from 2010.
    I need the following, if anyone can help me:
    - Does anyone have UPDATE or a newer version of "XILOG MAESTRO-EDITOR" to send me, and can work with my USB key for him?
    - I saw that MAESTRO has some limitations, so I started practicing work on ALPHACAM, so I need an explanation on how to EXPORT to a PGM or PGMX file, is there any post processor for MORBIDELLI m100?
    Any help would be welcome, I saw on the internet similar questions were asked by other MAESTRO program users. So let's help me and the others ...
    Thanks in advance!
  19. #39
    Member cncup's Avatar
    Mar 2022
    Newbie!
    Where I can find SCM Maestro for training.
    Wood Working Industry.
    Thanks a lot guys
  20. #40
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    If you have an SCM machine, SCM should be able to send you a link to a demo version they have.
    UCCNC 2017 Screenset
