You should have a shortcut to WinXIso in your STart menu, probably under SCM or SCM group. If not, you can just double click the file to start it. Once open, click the folder icon in the upper right corner, and select your .xxl files.
Then click the arrows on the right side of the screen (next to the file names) and the files will be converted to .pgm files.
