Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Cincinnati CNC
Cincinnati CNC Discuss Cincinnati CNC machines here.
Old 02-15-2010, 01:01 PM
sarniamachining is on a distinguished road
Manuals and check input signal
Hi, I have just got a Cincinnati Milacron (Year 1995) Sabre 750 Vertical Machining Centre. With Acramatic 2100 Control, and I am looking for any manuals for this machine. can anyone help me Please.
I have never used one of these types VMC before,
I have only had the machine about a week, I powered up the machine and the fans on the main swich box come alive, but nothing happened to the screen, I then found out that I had to push the green button on the front panel, then the screen started to show things, after a few things had come up on the screen it then come up saying, (check input signal) this was in a blue outlined box, and then I could not do anything else, and the screen goes blank. If you could help me to get past this point it would be great.
(PS I live in Guernsey, Channel Islands, UK, so to get training is not so easy.)
Old 02-16-2010, 03:28 PM
Up data
Hi Again,
Things have advanced a little since my last message.
Some manuals have been located and i am waiting their arrival.
I have discovered the following procedure will get life into the control monitor screen:-Wait a few minutes after the screen has given up and gone blank, break power to the monitor,wait a few more minutes then re-connect power to screen. The screen then comes to life and stays good with the Acramatic software active.
The green button is a mystery,sometimes it has initiated startup & sometimes only way to start is to push in the small contactor which green button drives when it chooses. The contactor does self latch.
Relevant to above is that machine appears to have been updated with a TFT screen.
Any thoughts welcome.
Old 02-17-2010, 06:02 AM
mallardfizz is on a distinguished road
Hello send me an e-mail to mallard@fizz58.freeserve.co.uk with your phone number and i'll give you a ring to discuss your machine problem
regards
mallardfizz
Parallel port: How to check Step signal? satanicoo General Electronics Discussion 6 07-08-2010 04:00 PM
stablizing vfd input signal keithmech General Electronics Discussion 1 04-23-2009 03:24 PM
Need Help!- Input/output signal on 0M-C padobranac Fanuc 3 10-28-2008 09:49 AM
Input signal fails when powering up drivers. Witsenburg General Electronics Discussion 2 07-02-2007 03:02 PM
Physical Button Signal Input Triggering Macro sunmix Mach Software (ArtSoft software) 0 08-24-2006 10:26 PM
