Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Cincinnati CNC
Cincinnati CNC Discuss Cincinnati CNC machines here.
Old 02-09-2010, 01:34 PM
brokenrinker is on a distinguished road
G43 dumb question
This is a generic G code question not specific to Acromatic control.
As I understand it a G43 command engages tool length compensation. However on every machine I've ever used, doing a tool change (M6TX) engages the tool length compensation value found in the tool database. There doesn't appear to be any reason to use G43 HX
Am I missing something? What is the point in G43? When do you make use of it?
Old 02-09-2010, 02:22 PM
christinandavid's Avatar
christinandavid is on a distinguished road
G43 is needed
If you have only used Acramatic you won't have used G43.
It is required on most other controls and can be useful if you want to apply different tool lengths for the same tool. T_ M6 will not load up offsets automatically unless you make it part of your tool call macro.
DP
Old 02-09-2010, 04:22 PM
Thank you. That helps.
Old 02-10-2010, 07:53 AM
scudzuki is on a distinguished road
In the past I have run a number of different controls that assumed the length and radius offsets of a tool once it was in the spindle.
It's pretty easy to acclimate to adding a
G43 H(#)
after every
M6 T(#)
You get used to it.
Joe
Dumb Question Pretorien Benchtop Machines 5 10-11-2007 11:15 AM
Dumb Question... grasshorse General Metal Working Machines 3 06-28-2007 11:15 AM
One Dumb Question Biggermens General Metalwork Discussion 14 04-11-2007 03:49 AM
Seriously dumb CAM question sploo General CAM Discussion 9 03-09-2006 04:55 PM
-OK I'll be the first to ask some dumb question- Ol'Dusty 80/20, TSLOTS and other Aluminum Framing Systems 0 11-11-2004 08:32 AM
