Results 1 to 3 of 3
Thread: Combining grid hole and pocket cycles
    Dec 2009
    uk
    I am very new to cnc milling so please be patient.
    I have a cincinatti arrow 500 (ct control)
    the code i am using is for drilling and counter boring :-
    6mm hole
    G81X40Y0Z-7R2E1
    G173X40Y0U330V84D16P8
    c/bore 8mm e/mill
    G81X40Y0Z-3R2E1
    This works fine, But i want to include a pocket cycle to make 9.3mm c/bore using the 8mm end mill.
    any help would be greatly appriciated
    Gixermick34
    Jan 2008
    I think you need to mill a circular pocket in each location. I am unaware of there being a G code that will do that for you. You can repeat and rotate/ translate the pocket if you do not want to figure out the coordinates of each location.
    Dec 2009
    uk
    Thanks for the reply at least now i wont be searching for a G code that doesn't exist.
    Gixermick34
  1. Cutting a pocket around a hole
    By pzzamakr1980 in forum Mastercam
    Last Post: 05-17-2010, 08:04 PM
  2. Pocket cycles
    By digitalni in forum EdgeCam
    Last Post: 07-08-2009, 06:42 PM
  3. 2 or more CO2 Laser beams combining?
    By Konstantin in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 02-21-2009, 01:08 PM
  4. Need Help!- Combining DXF in A9CAD
    By blue_steel in forum OpenSource Software
    Last Post: 01-29-2009, 07:38 PM
  5. Combining woodworking with CNC
    By Patrick2by4 in forum WoodWorking
    Last Post: 10-29-2006, 07:44 PM
