Hi! I'm trying to find out what machine this ground ballscrew goes to:
Cincinnati Lathe Z-axis P/N 3632063-R01
Is there a catalog or something that I can look this up? Thanks!
I was just wondering if anybody would be interested in a precision ball screw for a Cincinnati Lathe Z-axis P/N 3632063-R01? I picked it up from a surplus store but I can't find a good application for it (that would fit in my garage). If no one is interested, I'll have to put it on ebay or something.
did u try https://commerce.cinmach.com/default.htm? I think you can type in CMI part numbers and get inof/availability on them. that is a cmi lathe part number so maybe you can get info that way.
Hi! Thanks for the tip. Unfortunately, it just says it's a ballscrew but doesn't say what machine it goes to. Are there parts lists for the lathes?
This was designed 6/10/1975, used on all 12" machines and 18" shaft (whatever that means). X axis. it is preloaded, 1.75" dia, has .25" dia balls, 8mm lead, lead error not to exceed .0005" per foot, 700-800# preload, tested to 7.8E6# stiffness, looks like 41.25" overall length, assembly includes screw, stop collor, some screw & nut, roll pin, ball nut.
Enough info?
Thanks for the info!
I just put the ballscrew on ebay if anybody is interested:
Ground Ballscrew for Cincinnati lathe, z-axis, cnc - eBay (item 190501481456 end time Feb-19-11 16:49:32 PST)
